S4 first gen indictor?
Goatpoker
I'm adding a gear indicator switch to my gen1 S4. I'd like to use it with my Holley Dash, has anyone done this and willing to share the details?
I will be doing the same on mine soon. This is how I am going to do it on the Holley system.
0-5 volts in/out so should be similar as this video.
I have set up about 5 of them,
Pretty easy with the Holley,
just set it up like the Alternator readout, readout is volts,
S0 setting up a volt meter,
On the Side you can read what is on the dash, for example you will have 1 2 3 4, volts for ready out
and on the bottom scale, you will put .75-1.25 equal 1, and 1.75-2.10 equals 2
you want to set up a range of volts to read the output number on the dash, that way you do not have the number on the dash move around,
I start with checking the voltage on the sensor at the transaxle,
But all and all you are just setting up a volt meter,
This is a really hard way to set up a Stick shift, good for a automatic, but i would do a volt meter process,
will send a pick of the setup, take only a couple of minutes to setup the volt meter process
Im interested in seeing how you did this too, i need to get it setup in my car
Pull up the Input output tab i/o
Call it any Name, i use Shift
Then enable the Shift Icon on the Right on the I/o page
Then pull up the Pin Map, drop the Shift into the output you want,
Go back to the Input output, pick 5v,
When opening up the screen attached on the Left drop down pick
Custom 5V and then add your data to the screen
The bottom of the screen is the voltage, the top of the screen is what will read out on the holley screen
Just in Case Let Me Start from the beginning,
First open up the Holley Soft,
Then go to top tab marked
Toolbox,
Open the Toolbox and
Click on the IO Folder
Back to the Main Screen
It will have a Icon next to the Fuel injector Icon with a I/O
You will see the Input Tab, call it Shifter, then Type is 5V, Enable needs to be clicked,
After this you can click the Configure page
The next page will be where the data in put into place,
Next use the dropdown and pick
Custon 5V
Use the CUSTOM 5 VOLT AT THE VERY BOTTOM OF THE TAB show below right below 5v
Next check you output on the trans
Mine was around 1v for first,
so this is my cal chart,
make it a variable voltage so the screen does not change much
Voltage is the bottom in Blue, Top in white will be what is on the holley screen
For anyone doing this,
From the PM's i got,
you need to start from the basics,
Get this working with a Hand Held Volt Meter before setting up the holley,
RECORD THE DATA FROM VOLT METER,
Just set one up last night on a car that Im working on for a freind. Everything was pretty much how Alper described above except once all of that was complete then had to go into the pin map and assign that input to an ecu pin.
I was also able to add an in tank fuel gauge into the holley screen as well if anyone is interested in that info20250826_175101.jpg
