Rockwood
- 8,013
They sound like auctioneers.
this is something that has always intrigued me and i would not mind owning one. Crisp clear throttle response and well tuned carburetors.
Like a good fart in the morning!this is something that has always intrigued me and i would not mind owning one. Crisp clear throttle response and well tuned carburetors.
up next is the "Dunes and Desert" clutch cover https://speedutvparts.com/products/dd-clutch-cover $425
now standard on all current models delivered July 2025... mostly unless QC missed it
Well at least RG learned from the failed Wildcat XX drivelines. LOL!!!the drive shaft - bearing removal fix??? WTH, the frames must be flexing enough to takeout the bearing or snap the thin wall weld and the fix is to remove it and add a safety hoop.
Funny the Wildcat XX has a similar driveshaft crown spline adapter like this and they failed at the weld too
He is going to get every ounce of money out of the owners for his design flaw fixes that probably do very little.up next is the "Dunes and Desert" clutch cover https://speedutvparts.com/products/dd-clutch-cover $425
Speed after a shitty showing in rocks making clicking noises and torque limiter failure:up next is the "Dunes and Desert" clutch cover https://speedutvparts.com/products/dd-clutch-cover $425
Needs more cow bell.
But, we were told the suspension looks funny and wouldn’t work!Ill stick with this one
You catch up a lot faster when people leave the line.So .....
Swapping cars, changing the numbers, and re-wraping them...
Is their idea of getting caught up?
