JPhomie
- Sep 4, 2024
- 6
- 1
Yea John at outfront is the guy, I have a micro tech computer, and he doesn't work with those unfortunately.Most guys trailer their cars to John at Outfront. I know its not the answer your looking for but the silence to your question speaks for it's self.
Little more info on your radiator may help. Size, engine Hp, location of the radiator, any changes prior to the temp issue?
Thanks for tips, going with 2 fan setup and changing the mount to be al ittle higher might be the move here.Can check with Dardan if your looking for tuning. Maybe some of the AZ guys can chime in on tuners in AZ.
The fuel tank isn't helping on air flow to the radiator. The single fan is well just that. The radiator appears to be substantial in size, just need the clean air flow and IMO 2 fans with a shroud. You might get lucky with a 2 fan upgrade.
thanks for the help. I'll look into a dual fan setup. Also, might change the mounts to lift the radiator up to increase the air flow.1993 legacy Subaru 2.0 turbo running 9psi. I had a single fan set up, car came that way. Built in 2008, I got it in 2016. It wouod be fine on cool days getting to 210° but if drove hard or it was warm out it would go up to 230°+. I figured out how to make a dual fan setup work and what a game changer. No matter how hard i run or how hot it is i never get above 185°. Fwiw just some inspiration to get you going on it. And yeah I trailered to John from mesa (i couldnt find anyone to tune in phx. Area) when i redid my cpu (linksys finally gave out). I couldn’t find any pics. But mine was behind engine in wing still a super tight fit. I had to modify a little and went with something like this
Top Street Performance HC7106 Top Street Performance Pro Series Electric Cooling Fans | Summit Racing
Free Shipping - Top Street Performance Pro Series Electric Cooling Fans with qualifying orders of $109. Shop Fans, Electric at Summit Racing.www.summitracing.com
Dodd, do you have photo of your car? curious if your setup is the same? Maybe my single fan isn't as powerful?I have the same car With same Subaru 450 hp. Has same size radiator with one large fan. Never gets over 200 on hard runs even on high boost, I don’t have a windshield either
Perfect, that would be cool to see your setup, always rad to see another AG build. Funny I was in SD and then moved out PHX few months ago.I am out of town until Monday. Can get you some photos when I get back. Car weighs about 1800# I’ll get you some photos what part of town are you in? I’m in Ramona ca
