America...Eff Yeah!!!
dbart
Been wanting to do this project for a while. After we had the house painted and put up new gutters, I could not install my flag mount!
So... obvious choice is a in ground flagpole set up!
I went with Service First, American made and Veteran Owned, 20' telescoping with (2) flag mounts, solar light and flash cover for the base!
So, the project: I got the concrete, drainage rocks, plastic drain, Flagpole, flags (it came with the American one and I ordered the Back the Blue edition).
Ready to go!
Starting out, I didn't know exactly where my sprinkler lines were going or crossing, etc...so I put an extension on my drill for cutting wood holes and went around in the basic diameter I had marked out. Went down about 14: or so...that worked well, I could go slowly, and it broke up the dirt as I drilled. Then moved into the center portion and then just dug it out.
I kept doing this as I got deeper...I found it to work awesome as I didn't really have to dig hard. The drill bit loosened up everything and actually cut through some roots.
My neighbor lent me his fence post digger, that was awesome!
When all was dug, put some drainage rocks in, set a drain at the bottom, put the PCV sleeve in place and started mixing concrete!
OMG...what was I thinking??? Mixing concrete in a wheelbarrow is no fun at all!
Plus, I have never done it, but luckily my neighbor was over and learned me a thing or 2!
But when all was said and done, I put the pole in the base as the concrete was drying to make sure it was level in 2 directions.
Came out pretty good!
I then wanted to clean up the concrete, so I got some planter border and black rocks to clean it all up!
Done, I love it!
20250603_123637.jpg20250601_091709.jpg20250601_092536.jpg20250601_095830.jpg20250601_104930.jpg20250601_110547.jpg20250601_112535.jpg20250601_122951.jpg20250601_081238.jpg20250601_123333.jpg20250601_123758.jpg20250601_151151.jpg20250601_170017.jpg20250601_170023.jpg20250603_123601.jpg20250603_123620.jpg20250603_123624.jpg20250603_123637.jpg
Badass! I have a 50ft'er I want to install at my main gate. I was going to hire guys to do the work but after looking at your work, I'm confident I can do it myself! Thanks!
I guess I have to be that guy. You pussies...😄
I'm surprised your OCD didn't get the best of you but it got the best of me, that's why I have to bring it up. 🤣
Great work boss! You always show pride of ownership!
I know, I KNOW!!!! LMAO
...I had it a little better when it was still wet, but at the point I snapped to pic it was pretty well dry.
Can't even tell when it is fully extended!
50'er...WOW
That is going to be a pretty massive hole you have to dig.
Probably 3 times to size of what I dug. Mine was 18"w x 21" deep. took all (6) 50 lb. bags too. You will need probably triple that.
I would rent a small cement mixer if you are going to do it yourself.
If you don't use a mixer I used a hoe instead of a shovel to mix it in my wheelbarrow...it worked awesome but man it is a lot of work.
What I am really trying to say is, hire someone!!!! LOL
Cheers maing. 🍻
Nice job.
I order 3 flags at a time to have them on standby for when they fade or start to fray. https://a.co/d/f4bZkzH
I know some will give me shit but the US made flags are way too expensive and don't hold up any better. Havasu is hard on flags for sure.
Awesome, Thanks Mac!
I call BS. Did you really dig a hole and put cement or is this Photo Shop AI ? Nice work homie. Looks like it was about a 6 beer project ?
My neighbor and I had about 5 beers after!
I was spent.
LOL
Nice job.
My flags seem to last only 6 mos. or so. I live in a freaking wind tunnel it seems. I've tried different brands with none standing out better than the others. Trying this one and if the results are the same, I'm going to go with less expensive and keep spares as you do.
