J Alper
Site Sponsor
- Apr 30, 2021
- 2,066
- 1,793
2016 Blazen F395 by Pacific Coach Works,
$41,000 or best offer.
17 foot separate Garage
Not sure where to start, any suggestions will be great, Inside was professionally cleaned, outside i just had washed and fiberglass buffed,
Las year a FLEX-ARMOR roof was installed, this is a seamless roof with Zero maintenance, this is a fiber impregnated spray roof, was around $15,000 upgrade,
Tires, Sailun 637 G-rated 245/85-16 was purchased 2 years ago,
New forged Rims, had a crack in one of the original rims, replaced all 6
Spare Tire is a 637 Sailun
Added 20 gallon Factory Generator Tank kit by LCI
Fuel Station is 40 Gallons with 3/4 line running from the fuel station to the tank, it pump like a gas station pump,
Dual 7 Gallon Propane tanks with built in mechanical fuel level gauges
Upgraded the Lippert level up to a BIG FOOT hydraulic leveling system with 2'' solid steel rams
New style Lippert Screen Doors and New Lippert door windows with build in shades,
Currently has a Goosebox by Popup,
Wheel bearings were done last year with Timken Double Lip Seals
6 Volt batteries were installed in October,
Added a 8 button Switch-Pros to run Exterior unground lighting and to override the front level jacks for easy hitch hookup
Bolted to the frame inside the Garage are 4 5000lbs tie down latches for full size sandcar,
New, Tomas Payne Couches with massaging and heated seats with underglow lighting
Bauer Bluetooth door handles, can run from Iphone,
Furion 3300 Radios in Garage and in Living Room
Kenwood marine speakers on the outside slide
The Items above, i have added to the trailer that did not come standard,
