Jtmoney714
- May 6, 2021
- 875
- 751
Pros and cons to running either the large or small boots. Which do you prefer and why?
I was hoping someone would offer an opposing opinion to better explain this. I do believe the answer is it's car and driver specific.Small boots tend to sling grease, and you have to pull the bolts to check the grease. Large boots (Bates over-boot) seal better and you only need to remove the hose clamp to check the grease.
In depth-I was hoping someone would offer an opposing opinion to better explain this. I do believe the answer is it's car and driver specific.
The ease of inspecting and and adding grease is valid. I still run into the issue of the clamps rubbing on my hub/rear spindle. My car is so light, I don't get the wear and tear that bigger and heavier cars have. I've never had to add grease during a season.
I think the clamps hitting the inside of the trailing arm is an issue with SU. Mine hit as well. I was going to start to run the empi clamp that is low profile but requires the tool to tighten.I was hoping someone would offer an opposing opinion to better explain this. I do believe the answer is it's car and driver specific.
I safety wire my CV boots instead of using clampsI was hoping someone would offer an opposing opinion to better explain this. I do believe the answer is it's car and driver specific.
Use loctite before adding grease.On my SU car I run the smaller boots no problem. On my Buckshot it had over the bolts boots. Hated them, can't check the torque ever. Yes they do loosen up over time. Good luck with the loctite with all the grease. Changed them to the smaller boot.
