Squealing clutch
Ganzo
Jan 1, 2023
108
12
Hey guys whats up i have been having an issue with my clutch squealing. I have a built 091 mated to a j35. When im going cruising at any speed and i put the clutch in for any reason, as soon as i release the clutch you hear a loud squeal comimg from what i think is the throwout bearing. I replaced th T/O bearing and still same issue. My bearing is not staying touching the pressure plate cuz i checked that already. Any ideas?
Clutch disc is slipping. Some causes of this could be a warped flywheel or pressure plate, clutch disc is worn out, clutch not sized correctly for your HP/torque or mismatched parts. Some clutch discs (sintered iron) will squeal slightly when engaging them but not much.
