No probably deadThat will get ya Pink eye
No probably dead
But what a way to goNo probably dead
Lose my number
I finally got the throttle assembly and installed it. Got the check engine light to go off. Now I need to do some drive cycles through it. So I can pass that stupid fucking rule that Newscum put in place.Is the Moho fixed?
Are you planning on using a mobile smog company?I finally got the throttle assembly and installed it. Got the check engine light to go off. Now I need to do some drive cycles through it. So I can pass that stupid fucking rule that Newscum put in place.
I’ve got a fellow mechanic that started his own business of certifying the trucks. He’s the one that was able to figure out the 35 codes I had on my motorhome. The last piece of the puzzle was the throttle pedal.Are you planning on using a mobile smog company?
