Whipsandshyt
- May 7, 2021
- 130
- 125
Is the a real difference in diameter? I understand more splines is more surface area. And if they have added splines doesn't that make the star thinner? I also know some axles taper so that the axle is smaller than the spline area. Is this the case with 35 spline?
I'm trying to decide if I need the bigger set up. My car is 3200# maybe 800 wheel and 35.5 tire, midboard hub
Thanks Jeff
Thanks Jeff
