ChasingSand
- 873
I am thinking of rewiring my car in the off season as I am tired of the rats nest I currently have. My car is super basic and I am thinking I can tackle it myself.
I do have a couple of concerns and questions and hoping someone can chime in.
For my Ignition on items, such as Relays, Electric Power Steering, ETC. I was thinking of using the SPOD bantam X(Already have it) to trigger a bus bar with all the "Hot" Items to it?
Secondly, for the MSD solid state, I want to run my fans and fuel pump on this. The fuel pump should be easy but I am confused on the fans as I use a switch inline with the coolan line that triggers the ground to the relay. How is this done with the MSD unit?
For two lights (Baja XL80's) it looks like with the SPOD I can ditch all the relays and run straight to the controller? Can you wire two lights into one port? They draw 5.5 Amps per light.
Lastly, what does a typical rewire on a chassis run? I already have a mil spec engine harness and just need the chassis done. Might be cheaper in the long run to have someone do it for me. I was burned super bad by Erik at Hardwired Performance so I am a little gun shy in regards to the matter.
