Jtmoney714
- 921
Has anyone mounted a starlink roam set up on the roof of your motorhome? Does it still work while in motion?
Which mount did you use on the RV?I mounted the Gen 3 antenna to my roof - works great. I also have one mounted on my boat and it works great too.
Does the mini work well enough to stream Netflix or sports games?I have a Mini setup that works perfect in motion. It is suction cup mounted to a skylight over the bunk bed.
yes it works perfect. I have a cigarette lighter plug that I use when moving, but run it on 110v though the RV wen parked.Does the mini work well enough to stream Netflix or sports games?
I used this mount. Worked perfect.Which mount did you use on the RV?
