Funco4JM
- 144
Well in in early 2024 I decided I wanted to redo the Funco. Ill post up before and after and add in some progress pics as well.
Car started off as a 2004 Gen 4 with a Turbo Honda and Fortin Sequential. No frills but did have a full body.
Here is the list of changes made -
Chassis -
Gen 6 front end, radius roof, stretch rear cage, enclose rear doors and add steps, add doors to front, raise radiator, upper and lower motor mounts for LS, Upper transmission Brace, triangulate rear removable engine cage, add gussets and additional tubing for strength all around car as needed, new full body, curved windshield, dash, center console, radiator cover, cooler mount, foot rest, steering shaft and mount, APR Carbon Rear wing, Im sure im forgetting some things.
Engine -
LS6 swap, Tom Face Headers 2into1, Motion Raceworks Catch Cans and Steam Vent setup, 20AN radiator hoses, BTR valve covers and plug wires, Sweet P/S pump, Aeromotive brushless A1000 with Pre and Post filters and fuel shut off.
Fortin -
Full rebuild, new R/P, new 3rd gear, all new diff gears, new oil pump
Electrical -
Auto Meter Digital Dash with Speedometer, Switch Pros 9100 x2, Lowrance HDS7 Live GPS, Airlift 3P system, Rugged Radios with Car to Car, all lights LED Baja Designs, USB chargers for phones, dual odyssey PC925 batteries, full rewire of engine/car.
Misc -
Funco MPI Steering wheel and quick release, 17" Rear wheels with 14.50x17 #2 cut rear paddles, Funco Shifter/turn brake setup, driver seat slider, Moved fuel fill to side of radiator shroud, Funco/King 3" Gen 6 shocks front and rear, Powder coating everything, all new PTFE hoses for brakes, P/S and fuel lines, new Timkin bearings in front and rear hubs, new CV's,
It was a long process and it took alot longer than I anticipated. But it came out amazing.
Thanks to the following for helping make it happen -
Jason at Next Level Motorsports
Ricky at Kartek
Dennie at Foddrill Mortorports
Kevin at McMullen Fabrication
Affordable Powder Coating
Chassis -
Engine -
Fortin -
Electrical -
Misc -
Ricky at Kartek
