Camlock Harnesses
C_landd
Looking for a camlock 5 point harness with padded shoulders and WITHOUT the racheting lap belts.
PRP has some, but i don't like the ratchet mechanism on the lap.
Any suggestions?
Thanks!
Crow and Simpson both offer Cam Lock belts. Most of use these brands. I personally use the latch type.
Will they do padded harnesses? I did not see that on any web page.... granted i havent called them either.
Crow will basically build them how you want them. Yes with sewn in padding. They will need some measurements from you. Best to call them. Super easy to work with.
I have what are you are looking for. Corbeau makes them.
A word of advice, take the cam lock apart when you buy them and clean all the grease out. Re lube with dry graphite, or some type of dry lube. They are a bitch with the grease, sand sticks in them. After cleaning and dry lube they are awesome.
Team Tech also has those options. The are pricey but the best belts I have ever had. Also have never had an issue with the camlock.
I thought you misspelled Kamala Harris. 😀
That would be the WOKE model, The new Kamala Whoreness, it doesn't work, it was designed by a DEI tree hugger dyke and it was assembled in China!
