Looking for a Honda 3.5 Ecu please
Snyper619
My Ecu is giving issues and am looking for a replacement. I believe it is a stock Ecu with the immobilizer flash. Motor is a 99 Honda Oddysey 3.5. Does anyone have one to sell or know where to get one?
Before you throw an ECU at it, what issues are you having?
These computers are pretty solid.
The #1 injector is stuck open, Noam test showed no pulsation just solid light, traced the wire back to Ecu with no breaks in wire, cut wire at Ecu and Noam test same result
The ECU pulses ground to the injector. It will have constant power. Were you using a Noid light to test this, or just probing the pin with a test light?
Also, do you mean "an ohm" test? Like checking resistance or continuity?
