EastMT
- Jul 21, 2022
- 974
- 631
I need to bend some 1-1/2" .120 wall mild steel tube. I'd like to bend it without the crinkle or flat spot. What are some good brands of used benders to look for , for the at home guy? Thanks
Pictures?I'll sell my electric/hydraulic JDSquared bender with 5 sets of dies. 2" w/6.5" radius, 1 1/2" w/5.5" radius, 1 1/2" w/4.5 radius, 1", 1/2". I don't use it very often and shop space is becoming more important.
$2k, delivery an option
Same. Works great and will even do most of a 90* on a shitty compressor without making you go completely insane.Another vote for JD Sqaure - and if you buy this cheapish hydraulic setup for it - you don't need to mount it to concrete - and have it on a roller stand...I have this setup and like it.
SWAG Formed Tubing Bender Air/Hydraulic Ram Mount
SWAG Formed Tube Bender Air/Hydraulic Ram Mount Tired of cranking the handle on your tubing bender? Are you using a 6' cheater bar slid over the factory handle to gain mechanical leverage, while trying to read the degree wheel that is ~8 feet away? This kit is designed out of pure necessity and...www.swagoffroad.com
Im on the road today, got some pics later.Pictures?
I have some straight hydraulic conduit benders for work, and they're amazingly fast. Keep hands/fingers away though. Zero fucks given if it's in there.I use to work for Hossfeld and have owned a Protools, rougefab, and now a swag, everthing i get from Eastwood works ok, but never impressed,
I use to bend tubing Horizontal for 20 years, went to a shop where they bent upwards, not that is how i do it, so much more accurate, you can set your tube at zero degrees then bend up, and check with a angle finder, I do not love air over hydraulic, it works ok, but full hydro like LRS is really nice even coverting it to vertical would be really easy,
Due to the bushing in the main pivot is what i was after on my last purchase, the bushing lets you take the die out without the bender coming apart,
Swag for me marked all the boxes,
Then i did the extra long ram from trick tools, and added a full hydraulic to the system, with pedal control,
