EastMT
- Jul 20, 2022
- 1,045
- 718
What is your preferred brand of high quality automotive relays?
I am looking at the MSD solid state unit as a long term replacement. But would like to know what relays others are using that are trouble free.With all of the switch panel options out there i would be looking at eliminating relays and using a simpler design that cleans also cleans up the wiring.
Hella. Get the ones with the water resistant connectors.
I had relays last 2 trips...... and they were wired correctly. No thanks.So I'll throw this out there...
MSD ignition products have sucked Hard since production went to China.
Even no name relays last for Ages when wired correctly.
Has anyone had any long term experiences with those MSD solid state relays?
Alex Arvizu has been using MSD for years now with different customers and has not had anyone complain about them.
I am talking Hella Relays that were blowing in my car and 2 buddies cars.Are you talking about the relays?
Or their ignition products?
I replaced more MSD ignition products than I can count. Constant failures.
We switched to PerTronix and never looked back. Locally made and awesome support. They even Made a custom pick up for us one time!
Those MSD relays are pricey. Solid reviews though.
MSD 75643 Stand Alone Solid State Relay- Black https://a.co/d/2XkrZFe
I installed the MSD 7564 in 2023 when my entire car was rewired and all other types of relays were removed.
Is the Switch Pros running the fuel pump via the ECM, or on the ignition switch? Only bummer I see is you lose the "engine ain't spinning, no pump" safety feature.switch pros and MSD is the way to go. Easy to install and clean. I have a large manual reset breaker for the power steering and two blade fuses for the intercom and radio. No relays left.
