SeanRitchie
- May 6, 2021
- 444
- 1,017
https://weddleindustries.com/gear-calculator
https://weddleindustries.com/sites/weddleindustries.com/files/downloads/Current Gear Availability 4-1-21.pdf
There are a few ways to sort out what gear ratio will work for your specific application. Most trans builders tend to work with a "common" set of ratio's that they know most people are happy with when using common engines and power numbers, but you the individual can make some determinations on what might work for you car the way that you drive it and where it is mostly used.
Most typical sand cars will never see more than 100 MPH. If you want the most performance from your engine, you can start by figuring out what 4th gear will give you the desired top speed, at the max RPM of the engine. Using our gear calculator on our website, you will have to enter in R&P ratio, tire size, engine RPM (This should be the max RPM where the torque curve starts to fall off, and is the RPM where you will typically shift), then enter 1st-4th gears. 1st-3rd ratio's will simply be place holders until you figure out what 4th gear gives you the desired top speed.
Once the desired 4th gear is chosen, 1st through 3rd can be worked out to give even splits by using the "Percentage of Pull" box on the chart. When the percentages are even to each other, this means that each gear will feel like it has the same amount of acceleration after each shift. This is how most race cars are set up so there is no lag when shifting through the gears.
Another factor to consider is if you want to have a 2nd/3rd gear that is useful for duning, but have a longer 4th gear that offers an "overdrive" type gear to run lower RPM's on the longer flat runs. Then you would focus on the max speed for 3rd gear (which for most might be between 70-80 MPH in the dunes), then stretch 4th gear out a little bit to offer that overdrive effect. Be careful not to make 4th gear to "tall" and have too big of an RPM drop after shifting from 3rd as this can bog the engine and lower powered cars may not be able to pull that tall of a gear.
A few key terms when figuring out gear ratio's:
- High number on the gear = lower gear ratio, faster to accelerate, less top speed in that gear.
- Lower number on the gear = higher/taller gear ratio, slower to accelerate through the RPM, higher top speed.
- Percentage of Pull = even numbers offer equal acceleration feel with each shift. Lower number means shorter/faster accelerating gear. Higher number means taller/higher speed gear.
- RPM drops: Don't let these get too large towards 4th/5th gear or suffer a "bogging" gear with lower powered engines.
- Tire size: Taller tires equal taller/higher overall gear ratio's. Shorter tires can use taller gears. Taller tires need lower ratio gears to compensate for drive ratio.
- Gear strength: Lower ratio gears are weaker gears. Higher ratio gears are stronger. Gear strength needs to be balanced between R&P and 1st-4th gears to best overall trans reliability, especially with VW transaxles.
