megadesertdiesel
- Nov 8, 2021
- 879
- 1,248
No weep plates with slump block, wall plates are just a furring strip on the interior, Insulation is filled into the blockJust did this on my 2 story house. It was built in 1970 and had the same rough surface texture. I had to remove the lower 6 feet of stucco as the home was not built with weep screeds. It appears your home is not either. This lack of weep screed will result in water damage to your wall plates, lath and insulation. Good chance your in the same situation as I was as i dont see the weep screed and I do see stucco crumbling at the base of your walls.
On the smooth stucco deal. It looks amazing when done. Its not cheap. I am 65K into it with the wall repair, adding weep screed and lath, brown coat and full stucco on the house.
Would I do it again. Yes but......
I would remove all the stucco and do it right. Buy once cry once. Shear wall the whole house. This will lead to new windows too,
I have cracks in my smooth stucco. Its 1 year old. My high end Newport Beach clients have smooth stucco, they have cracks. All smooth stucco will crack with house movement. No way around it. Some of my clients have even crack filled and painted over their smooth stucco as it was the only way to make the cracks repairable so to speak.
Happy to discus in more detail.
