onanysunday
- May 7, 2021
- 3,729
- 3,438
So my 64 Dodge a100 truck project will have 750-800 HP. LS 6.0 Stroker and a 4l65 auto trans with 3000 stall converter. This thing will build some heat. I have approx. 15x12 on one side and 12x12 on the other. Not going to run through the trans cooler portion of the rad so that cooler will be remote and the only cooler. Just trying to decide what size and brand to buy for each. These will both be mounted up underneath in the middle of the truck laying basically horizontal or a slight angle. But not a lot of airflow. Found this article and they will be mounted like that. I have room to mount the exact coolers they used. https://inthegaragemedia.com/ls-engine-swap-oil-and-transmission-cooling-tips/ I do have a Setrab unit on the Funco up in fresh air with no fan. (Engine oil). Used a trans pump for a separate system so not using the engine oil pump to move the oil. Before that cooler I was seeing 275 degrees. After max of 235 and usually 210-220. What say you.
