More Topics for Sand Cars
I'd like to see more of your motor threads. I'd like to see a comparison of what a guys options are for what he could do at home with a junk yard pull or used engine for X dollars and get roughly Y horsepower compared to just spending X dollars with an engine builder. Not looking for any trade secrets just looking for good ideas and how much I could save or waste doing it myself.
It kind of Risk over Reward,  for me everytime i try to save the customer a little bit of money, something breaks and we are both staring at each other, what do to now, as simple as a lifter or not changing a valve, and as high end as a connecting rod,  so anymore the only stock rod builds is for local shops that are a 100% with a 60K mile warranty,  or maybe a street car with a small tire,
Anything that hits the dirt I like to put a non cast rod, They do a make a good upgraded rod for cheap, and then rebalance the crank for the correct BOB weight,
Quick HP,  Camshaft,  and springs,  you can run up to a .600 lift with any stock motor,  and add a good head Like a Small bore LS3/7 then you can get close to 600hp on a ls3 and the Torque will stay close to the same,
That would be awesome.   Topics????
Sounds like a plan,
Cool idea.  :dude:
All new builds will try to take some quick pics,  and answer any questions,
Yes sir! Please do!
Will take pics of all the builds Big to Small will make it a point,
Will start with the Disassembly and some of the work we have to do, then can get into the build process,
