Dockmaster
- 1,086
I'm in the que and will have a new Funco built starting this fall. I will need to make a decision on what trans to go with here shortly in order to get a trans in time to support the build. I've already selected the engine and have the long lead items ordered there. The car will be a GTU based chassis built in a 2 seat configuration. Engine will be a LS7 - 427 RHS block, Franken Monster heads with a 4.5 Whipple. It will be tuned for 91 pump gas and engine builder says it will make about 1k hp at crank and likely just a bit under 800 hp at the wheels. My trans options are either an S5D or Albins 5 speed. Sean at Weddle has weighed in and suggested I would pushing the limits of the hp and torque rating of the S5D. Others have suggested the ratings are very conservative. I have talked to a number of folks that own or have owned similar or near exact same cars, some with Albins and some with S5D's. Even talked to some that are pushing quite a bit more hp through an S5D. None with S5D have mentioned any issues or complaints. No complaints from those with Albins either other than a few comments on cost of parts when due for service.
I'm aware that the S4D has wider gears as compared to the S5D and thus stronger. However, a 5 speed is required so the S4D isn't an option.
I was planning to go with the S5D as I felt the only real issue might be future resale when and if the time comes to sell. Then I saw I recent ad for a near-new Funco for sale with an S5D. The first three comments on the ad were A-holes berating the asking price and sale because it doesn't have an Albins. Even though I think it's BS for people to comment like that, it got me thinking that the resale issue may be a bigger deal than I thought.
This isn't an issue of having the $$ for the Albins vs S5D. The issue is if it necessary the spend the extra $$ for the Albins both in initial purchase and future servicing.
Thanks in advance for your input.
