Vinsanity
- May 6, 2021
- 150
- 51
This - but for a few hours. Mine got into a funk during our January trip and that's what Xantrex tech support said to try first. I had already done it for a short while at first, but it really needed a few hours to fully reset.Disconnect dc and ac power from inverter and try to reset.
Contactors not BreakersSo opened what I believe is the transfer switch. With shoreline plugged in. I’ve got power through the breaker on the left but nothing coming through the one on the right.
I'll have to check that. On my remote panel the far right switch is it engage the charger so I don't know if that'll allow me to charge since it isn't working.With the generator on, are your house batteries charging?
This sounds like the breakers on the generator have tripped.Ok I disconnected everything over night. Re hooked up and didn’t solve the issue.
My other issue now is I have no house power at all. I have a 30 amp at my house that I connected to and tested the other day with no issues. Microwave worked/AC worked. As of yesterday I’ve got nothing now. Just turned the generator and still nothing. Tested my power into the coach and it works. Any ideas?
I hooked all the inverter up right and once it didn’t work I decided to leave it off. If the inverter is off but plugged into shoreline I should still have power.
