Ls Swap Sand Limo
TrayMan
Bought this sand car a year ago and time for some upgrades. Car originally had a SC Eco Tec 2.0 in it that got hurt at the end of last season. I sold that whole motor setup and just picked up an LS6. LS is all torn down now and at the shop getting cleaned up. Motor came with Intake but no drive accessories / sensors. Anyone have an "old" water pump/ power steering pump/ tensioner etc sitting around and want to clear up some space?
Im also in need of a clutch, flywheel, and headers
Holley terminator x should be here this week!
Where are you located? I have some of that stuff laying around i pulled off a motor i bought from a member here. Im in Norco, Ca. If you are local enough for it to be worth it.
i have: waterpump, harmonic balancer/crank pulley, tensioner, alt bracket with idler and i think a p/s bracket.
Maybe consider throwing a little extra cheddar at the project and buying electric power steering?
Where are you located?  I have a set of headers that are coming off my car this weekend and a KRC P/S Pump with attached resi I am replacing.
Edit - I also have a set of OEM spark plug wires you can have if you want them.
I'm located in Mesa AZ. Willing to travel around the valley.
I am in East Mesa, have some old parts before I added a blower.
Let me know and you can come over and see what I have.
Im in AZ. have any pictures of headers?
I also have the KRC power steering pump with attached resi coming off the car too.
send me some pics/ prices on these Headers for sale!
Sweet car! Keep us updated on your progress. These guys here will steer you straight!
Picked up a set of Headers and got the Engine back from machine shop. Ready for the kitchen rebuild!
What fly wheel / clutch setup do I want? Will be paired up to my 2D transmission.
What is the difference in stage 1-2-3 clutch? Plus minus of one over another?
My old ecotec had a stage 3 clutch and was very hard to push the pedal
I was going to say the same, if you can  use a polymer intake it will keep the Air Temps down,  Air Temps can be loss of power or worse detonation.
I was under the assumption the intake could simply be unbolted and turned 180? Have a recommendation for a reasonable priced replacement?
Thanks!
Yes the intake can be swapped 180, then typically the throttle bracket bolts to the back of the head
Great intake without breaking the bank is the LS3 intake with the Cathedral adapters,
ls3 oem intake bare | eBay  $260 shipped
billet fuel rails Deepmotor Billet Fuel Rail Kit GM LS3 for OE Intake Manifold W/ Hardwares | eBay  $70
adapters $75
LS1 Cathedral Port Cylinder Head to LS3 LSA ZL1 CTS-V Intake Manifold Adapter | eBay
With These adapters you will need a 6mm x 130mm same as the oil pan , 10 each,  or reach out to us we can get some out,
Oil pump to use,
Hope this helps
Thanks!
Stock intake can be used, flipped around.  No worries there.
