Mac
- May 3, 2021
- 947
- 2,193
Are you overheating now?Does anyone run or have any experience with performance coolants? I used to run Engine Ice in my dirt bike and quads but never in a car motor.
I found VP Stay Frosty but I was hoping for something that could get better results than 30 deg F cooler.
https://vpracingfuels.com/product/stay-frosty-racing-coolant/?c=361&
Agreed. Coolant won't fix over heating issues.You do have fans and I believe an intercooler fan. Coolant won't fix it if you have heating issues. Won't know till it's up and done.
Coolant will retain heat. It's antifreeze so keep the percentage below 50% and use distilled water.
is there an adapter to put an oil cooler on a Honda J354A, can the stock oil pump support?Add an oil cooler. Most people would be surprised how hot the oil is compared to coolant temps.
I would use a remote filter sandwich adapter.is there an adapter to put an oil cooler on a Honda J354A, can the stock oil pump support?
Yes that is the key. Probably 75-80% of sand cars don’t have an oil cooler because it looks cleaner or whatever but an oil cooler makes a huge difference. A big beautiful yuge oil cooler really helps.Add an oil cooler. Most people would be surprised how hot the oil is compared to coolant temps.
