DeepBusch69
- May 6, 2021
- 157
- 132
Referencing the wastegate off the manifold is a poor idea. If you have the issue you mentioned then your intercooler is too small. Drill and tap the housing in the same place. We do this daily. There are also other benefits by having the WG referenced off the turbo. Boost controllers like turbo reference better than intake tooMy reference line was hooked to the manifold. That was so the blow off valve was responding to what the motor was actually seeing not what the turbo was putting out. You could have 15 at the turbo housing but the motor could only actually be seeing 12. Is your boost gauge teed off that compressor fitting or is it referencing manifold pressure?
There's definitely two schools of thought about this. I would ask your tuner what he prefers.
I am glad I came across your post DB69. I am currently staring at my new turbo build and was considering moving my reference port to a different place this time, closer to the manifold. I had never heard or seen people doing it different than the turbo compressor, though. I will explore John's comment on boost controllers now, and re-think my decision. I have just recently been researching (articles and you tube videos) how electronic boost controllers actually work, and found out it is way more involved than I thought. John, can you provide details on your post about this subject, or share links to how the controller benefits from actual turbo boost at the compressor? DB69, we will have to share our final "outcomes" on these at our spring dune gathering. It will be good to dune with you again.
