ChasingSand
- 1,049
Summit Racing SME-906008 Summit Racing™ Harmonic Balancer Wrenches | Summit RacingAny link to one of these that works with a VW bellhousing / LS setup?
This will only work if the motor is completely, this would be a good option if the motor is out, and if the motor is out, then change the pilot bearing, and throw-out bearing
Anytime, It does not happen very often, but put a little antiseize on the crank shaft and inner part of the balancer, just in case it does not seize on the crank,Hit the bolt with a torch for about 1 minute and the big boy Milwaukee busted it loose. Thanks Jason for the tip. Now time to change the seal and reinstall.
Any tips on what to do / what tools to use to remove and re-install the new seal?Anytime, It does not happen very often, but put a little antiseize on the crank shaft and inner part of the balancer, just in case it does not seize on the crank,
Works every timebreaker bar and lock it off and bump the starter if all else fails
I like the 8.0 battery with the Milwak you have, NO extension, socket right on bolt, if you are using the stock bolt make sure it is a 5 point not a 12 point,Does the bolt need to be torqued to 250lbs or can you just send it with the big Milwaukee impact?
If you can't just send it.... how do you keep the pulley from spinning when torqueing it down? Motor is currently in the buggy... axles not installed yet.
