Looney Duner
- May 9, 2021
- 668
- 595
So I'm considering a few options for my engine build, I currently have an ls1, cnc ported heads, fast intake, bigger injectors, bla bla bla. Pretty basic set up, but it runs great. I recently picked up a kenne bell 2.6 blower, with a cathedral port intake. I'm going to build the ls1, and I'm contemplating going 383. The cost difference is a lot when you consider block work and such. Is it even worth it? I hear some people saying it's not worth the added cost on a boosted engine, just run a few higher psi and make up for the fewer cubes. Plus stroker motors don't rev as good as short stroke engines.
So if given the choice, 347 or 383, with 10-12 psi boost, which way would you go and why?
Edit to ad, it will be a forged bottom end no matter which size I go...
