Mac
- May 3, 2021
- 777
- 1,650
No. Most power sources are from standard residential or commercial buildings that are bonded. Inverter generators are not internally bonded.In bonding the nuetral and ground, does the adapter plug not do this already?
You have to put your charger setting to 5amps. Even that doesn’t work sometimes. I sold my 2000 also because of that.If my batteries were low my Honda 2000 would blow its fuse due to my MoHo charging pulling to many amps to charge the batteries. I would have to use the onboard Genny to get some charge in them and then switch back. Needless to say that program sucked and I sold the 2000. lol
I tried that and it was just a pain.You have to put your charger setting to 5amps. Even that doesn’t work sometimes. I sold my 2000 also because of that.
