SLIM
- May 6, 2021
- 459
- 383
I have had the same experienceI’ve had the best luck with cbr and have heard good things about c&r… I’ve had multiple Ron Davis radiators leak!
Another vote for CBR, thanks for replying.8 years and counting, no issues. CBR and
CBR Radiator Weld On Mounting Kit With Urethane Pads Will Also Fit PWR and Ron Davis Radiators - Kartek Off-Road
Thanks for the info. Was the leak anywhere a guy could get a small tig torch?CBR does not do repairs anymore. Just fyi. Good radiator but I had a leak in mine and their only fix was to buy a new one. I found an old school radiator shop who fixed it for $150
He was able to get to itThanks for the info. Was the leak anywhere a guy could get a small tig torch?
Thanks for your vote. I called CBR and asked for a quote on a 31"x19" with a heat exchanger, shroud, and fans. $2K, Bridenflation is killing me.My vote is cbr. From what i’ve seen doing repairs and installs cbr is not only better they are usually cheaper too
So why do you want a heat exchanger? Are you having temp issues?Thanks for your vote. I called CBR and asked for a quote on a 31"x19" with a heat exchanger, shroud, and fans. $2K, Bridenflation is killing me.
It was suggested on here. I didn't have any temp issues.So why do you want a heat exchanger? Are you having temp issues?
You don’t need a heat exchanger unless you have a turbo or supercharger.It was suggested on here. I didn't have any temp issues.
I’d run an external exchanger if you really need to cool the oil.It was suggested on here. I didn't have any temp issues.
