EastMT
- Jul 20, 2022
- 1,043
- 714
I use a drill bit do give the hardened shaft in the trans a small detent so the set screw sits inside it and the u joint won’t slip. I had one slip a little and that was my permanent fix.Don't know if you do it on shift shaft, but on steering I drill all the way thru the set screw and shaft and use a bolt with lock nut so there is no slip or failure.
Add, after thinking drilling thru the hardened shafts on trans might not be a good idea.
