EastMT
- Jul 21, 2022
- 980
- 640
How many inch or foot pounds do you torque the ring bolts to? Sand Limo brand wheels for reference.
What value do you normally torque your to?Those look like centerline rings and CMS wheels.
Same as I have on my car.
with everyone using electric impacts on everything, are they still Ugga Dugga's or something more like loud wood pecker.............3-4 ugga duggas
Crap, I won’t be back home for a few days. Will report back when I have those answers.What diameter bolt are you using? 1/4” or 5/16”?
Does your wheel have steel inserts for the bolt to thread into or is the wheel itself tapped?
Just great! Now I have to buy another torque wrench. None of mine have those increments.3-4 ugga duggas
I pay someone to do it. LOL.What value do you normally torque your to?
Be kind to that milwaukee. I saw a beadlock wheel that one of the bolts was torqued one ugga dugga more than a mofo and it broke.I crank mine down like a mofo! I mean, my milwaukee 3/8 impact does.
Thanks for the info and suggestions.I got the following info a friend that has worked on many sand cars professionally over the years. I asked specifically about Douglas wheels, since that is what our car has.
Douglas Wheel Torque Specs: Beadlock bolts
- 8" - 12" dia: 5.5-7.5 ft-lb / 65-90 in-lb
- 14" dia: 12-14 ft-lb / 144-168 in-lb
- 15" - 17" dia: 15 ft-lb / 180 in-lb
Tighten down bead rings in star pattern.
I followed this and it worked well. It did take a few passes because each time I tightened one to 15 ft-lb, the one next to it would be a little loose. Make sure to make a few passes to be sure you got all bolts torqued properly.
