Rockwood's Spotless Wash System
Rockwood
A year or 2 ago I bought this feller:
https://www.amazon.com/Aquatic-Life-Deionized-Spot-Free-Rinse/dp/B07H8MQTMD/ref=sr_1_1_sspa?crid=1FSAK96SSACN7&keywords=deionized+water+filter&qid=1692295106&sprefix=deionized+water+filter%2Caps%2C152&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
For spotless rinsing.  Works great, full flow, but I was eating resin like candy with our 350ppm swamp water, so I stopped using it.
A couple of months ago, I put an inline filter for it in the vain attempt of extending resin life.  It helped, a little, but not enough to matter.  $60 of DI resin lasted 2 months of washing, so that's $360/year for spotless rinse only, and I was being a super miserly Asian guy about it.  When I bought the filter, I assembled a detail cart to make life easier:
All with quick disconnects to make swapping between setups easy.  I use house water through the GE filter to fill buckets, rinse soap off, feed the pressure washer for the foam cannon, etc.  Hard water is better for suds, so I still use that for anything soapy.
This worked, but during the summer it's super annoying to wash a car as even in the evening shade, the water dries too quickly, especially with the graphene coating (most of it just slides off).  DI is nice, but if I was using it for all rinse stages...  Fawk, I'd be broke.
Enter the cheap ass (see a theme here?) Reverse Osmosis filter:
https://www.amazon.com/Aquatic-Life-Changing-Deionization-Cartridge/dp/B00204CQF6/ref=sr_1_11_sspa?keywords=reverse+osmosis+water+filter&qid=1692295640&sprefix=reverse+%2Caps%2C183&sr=8-11-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&psc=1
These filters will last YEARS for the volume I'm using to wash cars, but their flow capacity is nowhere near enough to rinse anything in a reasonable amount of time.  The DI setup flows a little over a gallon a minute, the reverse osmosis system is 100 gallons a DAY (0.07gpm).  Luckily, a storage barrel and some gravity will remedy this.  First, to prevent flooding everything when you forget, an auto shutoff valve and float are necessary:
https://www.amazon.com/dp/B00HZ6A476/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B00HZ6A476&pd_rd_w=6vZIP&content-id=amzn1.sym.eb7c1ac5-7c51-4df5-ba34-ca810f1f119a&pf_rd_p=eb7c1ac5-7c51-4df5-ba34-ca810f1f119a&pf_rd_r=ZDFGDX2YHG7EPGFH0V7N&pd_rd_wg=iyecr&pd_rd_r=e3734b0a-ea00-4253-99ee-e3f58518f2b1&s=pet-supplies&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw
I forgot to take pictures of the install, but it's a bulkhead fitting.  Simply drill an appropriate sized hole in the top of the barrel (7/8" in this case), deburr the edges, and install. I then installed this guy:
https://www.homedepot.com/p/Everbilt-3-4-in-Polyoxymethylene-Bulkhead-Union-With-Washer-Fitting-800479/207176307
Into the bottom of the barrel, again drilling a hole (1 5/8" this time), deburring and installing.  These are plastic, so don't reef on them.
After the fittings were installed, I rigged up a quick PVC plug with chit left over in the garage, filled the barrel, checked the float (it's adjustable) and let it sit for a couple of hours to ensure no leaks.
Once everything was confirmed to not leak, I built a mildly ghetto platform for the barrel in the rafters and wrestled it up there (120* up there, sweet).
(LOL, that lumber says "high quality" on it, which this contraption definitely isn't)
Before you ask, this barrel is in the absolute corner of my garage, less than 6" away from each wall.  My garage has a covered porch next to it with a vaulted ceiling, so the wall on this side of the garage is 5' taller than the other side of the peak.
After the 300lb tank was mostly probably should be unlikely to fall on my dumbass head while at my workbench, I bolted the RO filter assembly to the garage wall next to my washer/dryer, added a brass Y splitter to the cold water spigot for the washer (same as a garden hose fitting), plugged the RO filter in and ran it without the RO media for 5 minutes to clear out the pre-filters of garbage.  RO filters make waste water (this one is inefficient at a 2:1 ratio of waste to clean), so I simply ran the 1/4" line into my washer drain and shoved the end all the way to the bottom of the P-trap.  The auto shutoff valve was next (without it, the waste side will run continuously), which then was ran up to the rafters in my garage and over to the barrel.  To connect a hose, I ran PVC down from that bulkhead fitting (you can just see it in the bottom right of the above photo) to a 1/2 turn PVC valve (pure water is mildly corrosive, so avoid metal) to a garden hose fitting.  Crossing my fingers, I installed the RO media, turned the water supply on and watched it work.  This was 10pm, so I promptly went to bed, woke up at midnight panicking about leaks destroying everything, then went to bed after inspecting it.  This morning, the tank is full and no leaks, so hooray.
Testing the water, I initially got 20ppm TDS (the chit that causes spots), which has since fallen to 11ppm as the dust left in the tank dilutes.  The water comes out surprisingly quickly with all that elevation (6psi per the calcs) and should be plenty to keep the pressure washer full.  Unable to wait, I half-ass cleaned a dusty window on the Jeep and let the water dry in 90* of direct sunlight.
11ppm is apparently just enough to make no discernible spots (there's still some actual water that hasn't dried yet in this photo). Even if it never drops below 11, at this rate $60 of DI resin will last 5 years assuming it doesn't expire before then. Success!
Our well water is so hard I've gotta standby vehicles for 20minutes after drying to sop up any drips.  The smallest amount will dry like salty white tears
Same, except our Fords have spots that will drip for HOURS.  The spoiler on my Mustang also stores water that comes out the following day on the way to work...  Bullshet man.
Damn, you guys have some hard a$$ water. My last house was low to mid 100's on the TDS meter and I thought that was hard. New house is low 20's on the TDS meter and resin last forever it seems. I actually haven't changed it in 2 years.
I have been using a car blower to dry our vehicles. No more towels and it gets water out of the cracks and crevices (the C8 has more cracks and crevices than the Bunny Ranch) so no drippage or water leaking on the first drive after washing. The blower has castors but I wall mounted mine so I just grab the hose turn it on and start drying.
I use my Makita brushless leaf blower for the same thing. Always still seems to be some spot that water hides in. The hood has vents and stores a bunch in the rain catcher (go figure), which drains down to the headlights.
https://crspotless.com/product/simple-chuck/
Been using this for years with great results. Water in my city is horrible. I still probably get 20 washes out of it before I change the resin. That is my Yukon and long bed Silverado.
Nice. Resin being resin, it can only absorb only so many impurities before giving up the chemical ghost, regardless of the system.
My setup would last about 16 washes, so about $4 per wash for spotless rinse. Now it’s about $0.13 per wash, so should pay for itself in 3-4 months and I don’t have to be stingy at all.
I also absolutely hate swapping resin. Those resin beads end up EVERYWHERE. LOL
Wash a car in my driveway?  F that.
$7 and free vacuums.  Done.  The AZ sun is gonna F up the paint worse that the chitty drive through car was will...
My TBSS gets a "spotfree rinse" and a towel down at the DIY car wash....most of the time.
I wash the cars in the evenings or mornings in the shade. NFW I’m washing anything in direct sunlight, even my raisin of a Jeep. :biggrin:
And fawk that automatic swirl maker. Thought of it gives me the piss shivers.
In the ten years I've owned my XJ, it's never been washed.  My TJ has had one bath in two years.
I f'n hate washing cars.  Worse than making the bed.
Washing my cars is cathartic. :biggrin:
I bought the di rinse system from these guys https://rv-mods.com/store/ , they now sell their own product that looks the same. I watched their YouTube video and figured i might as well buy it from them. Di rinse, griots sell the same thing.
Small one is good for 2000 gallons depending on water conditions. You should be using a pressure washer to limit your gpm. I have a ryobi electric that I use on the truck/car and trailer.
I didn't do the math on costs, but it sure beats drying a 40' trailer or truck.
Nice, but resin is resin and is the major cost in DI setups for San Diego (one of the highest TDS water systems in the country other than well water). That unit will do 2,000 gallons at 110ppm, so 600 gallons or so for my water.  It uses 1 cu ft, so about $450 per year on resin for me washing 2 cars a week. The setup I built is $250 all in and will produce years of spot free water despite super hard water here. I expect to need to replace the filters and resin bi-annually, so $50/year ish on consumables.
The blue thing on my wash cart is a pressure washer, but I also have a flow restrictor to limit water consumption.
I tried everything with DI, and while it works great, it’s super expensive with my water. If I had OC water at 40ppm, I’d never even consider this setup.
That sounds like more of a PITA than making water for our saltwater aquarium. How about I just bring you a beer and you can wash my car? I am a Costco car wash guy and then a couple times a year I have my buddy the mobile detailer show up. Those swirly car washes are no worse than the Baja bushes for my Raptor. Now the new Bronco is a different story, the princess doesn't go through a car wash.
I've been detailing cars since the late 80's.
I've been through all of this BS for a Mobile Detailing setup for income and a home hobby setup.
Adam's Car Shampoo for washing (with no filters whatsoever, you can wash in the sun and let the soap dry before washing), blow dry with air and then go over the vehicle with Adam's Detail Spray.
This leaves no water spots, some gloss is added and is less work than pulling out the Spotless system, etc. I haven't used my DI setup for YEARS and get more compliments with those two products in my arsenal, than anything.
I also use HIGH quality microfiber towels from Luxury Microfiber with the Detail Spray (Spare me the micro marring comments, only .8% of the population cares or knows).
It's ALL work, somehow... why not have the last step add shine and some protection, rather than uncertainty?
I set this up so all I have to do is swap a quick disconnect fitting on my hose from the pressure supply on the hose to the fitting on this barrel.  All feeds through my pressure washer.  Everything's on the cart I wheel out in 30 seconds, and takes seconds to swap sources.
Half the time I wash it's not because the car is dirty, but just because it's dusty.  A quick 5-10 minute foam cannon and pressure rinse without drying would solve that, and this setup operates cheap enough to justify it.  I like a clean car, but I don't like spending 30-40 minutes a week per car handwashing when it's really not needed.
And I'm part of that 0.8% sir. :biggrin:
I'm part of that .8 percent too, way before Instagram made Detailing "a thing". I started using Turtle Wax in a can in the 80's... :lol:
Sounds like you're the perfect candidate for Adam's H2O Guard and Gloss. Use your foam cannon as you would, rinse with whatever water you want, spray the Guard and Gloss (fraction of a bottle for that Rustang, so cost isn't really an issue) while the car is wet and wipe it down. Streak and Spot free wash in 10 minutes, with added SI02 protection that your spot free water won't provide.
I was always a Meguiar's guy. :biggrin:
I have the Adam's stuff, ended up getting Chemical Guy's version of it because it was better at dust repellant, and I don't need to order it (store on the way home from work).
When I say dusty, I mean dusty.  My office is on the east end of the flightline at Montgomery and I live in Jamul.  It's 2-3 days before my garaged car has a visible coating, and a week before it's no longer shiny at all.  I like that stuff, but I still get the piss shivers from the process.  Doesn't feel right, you know?  :biggrin:
BTW, it's the track pack Mullestang, so all the coolers and other shet drop water continually on the next commute, and I look like (more of) a jackass Quick Detailing the streaks off at the office parking lot.  Seriously, Fack SD water. :biggrin:
