EastMT
- Jul 21, 2022
- 980
- 640
How many inches between your head and the roof / rollbar do you like to have to feel safe to not wear a helmet? Or under how many inches of clearance would you wear a helmet?
That sounds like a wise choice. Thanks.I decided not to test the belts and clearance, started wearing a helmet. Worse case, your head stays clean from the sand.
Thanks for the info and ancient proverb. I think I'll wear a helmet.None. Belt stretch is more than even @TheLatinLover’s shortest cousin in a XL frame with max head clearance can get away with.
Airbags exist because if your hands can comfortably reach the steering wheel, so can your face.
True, I just feel the day I don’t wear one is the day homeboy with only 83 payments left drives straight through the transition into me. Learned that racing: only lost control of my car once in 10 years of pro racing…. Last time I did it, someone pulled onto track at the apex while I was setting up a pass for P1.I don't wear a helmet. I now have a 5 seater which is mostly for tooling the kids around. I'm not doing anything that will absolutely require that helmet. Now if I'm feeling froggy, and I reach for a helmet, the kids know to stay at camp.
Is that 83 payments left on the machine, the stereo, or the wheels and tires?only 83 payments left
Naw, just the machine. They did the rest on a couple of different credit cards.Is that 83 payments left on the machine, the stereo, or the wheels and tires?
Or, have the lap belt in the middle of their stomach.and belts worn properly are important. I cant tell you how many folks Ive seen yank their shoulder belts so tight they are jammed into the seat but their lap belts are flopping around...... great way to get a spine injury.
That’s one of the reasons I like a 5 point harness. It helps keep everything where it should be.Or, have the lap belt in the middle of their stomach.
I ordered the anti-submarine belts that match the harnesses for that reason.That’s one of the reasons I like a 5 point harness. It helps keep everything where it should be.
The only acronyms I understood in that was SxS's.I am a Trauma/Critical Care RN studying to become a Hospitalist here shortly. I respect your choices to not wear helmets but on the flip side, I can't tell you how many TBI's I've dealt with in both Sxs's and SandRails because of a collision or rollover that have completely changed not on the lives of the driver but the whole family now dealing with caring for a TBI patient. I plan on wearing an Arai and will probably wear a Hans device or similar as Atlas (C1)/Axis(C2)/Bibasilar skull fractures in a harnessed seat are very real potentiality when your head goes slinging forward while your torso is locked in place not to mention the coup contracoup that yoru brain goes through. Just some food for thought.
~Andy
