Floor Pans - Leave Raw or Line it?
wesinls
Curious if anyone has rhino lined their floor pans and if so if it's worth it? Leving raw seems like the best idea, I guess I'm more curious what others have tried.
Linex on mine and IMO looks way better than raw aluminum. Wears really well. If you do go with aluminum have it etched and clear hard anodized.
Rhino lined on mine.
Has been that was since 2004.
Dropping them off today to get redone since car is apart.
Rhino line or linex for sure. Easy to clean etc.
I ended up putting non-skid on the floor of mine, getting in & out was almost dangerous with the way the step is on the outside and the angle of your foot when sliding in.
it worked great as a temp solution.
Linex is harder and more durable than Rhino lining.
Hmmmmmmm, I thought I had put a picture in my post...  guess not.  in any case, this is how it came out.  gooder enough for me.
Raw aluminum tends to put black scuffs on your shoes where they rub on floor. I did silver steel-it in contact areas on mine.
Personally, I don't linex, hard to clean if something gets spilled on it and it adds weight.  Diamond platting works just fine and easy to clean.
I don't have pics - but I ended up doing LineX - floor pan, two small sub floor pieces, and a foot rest...tops only.
$550 from the LineX shop in Santee...probably added 10 to 15 pounds?
