Whipsandshyt
- May 7, 2021
- 134
- 132
$150k work of fun for half the price. Handles like a slot car turns on a dime Long wheel base for stability
One of a kind Prowlers Long Travel located in Ramona CA call txt anytime 858 692-7211
130 in wheel base 36 in long trailing arms
Crate LSA with Pullies running E85 Fragola PTFE lines Injector Dynamic 1300 XDS around 14Psi, reinforced intercooler brick GM harness ECM and Fuse block
S4 PBS sequential trans pump 1 season on rebuild
934 CVs 33 spline axles
Switch Pro 8 postion. Oil, water, boost, voltage and fuel pressure guages.
Rugged radio and intercom, Jettrim seats
Whipsandshyt ball bearing shifter
Electric steering
4 Baja Designs Xl 80s
All shocks have adjusters
2 inch hollows
10.75 front tire 15 in rim
DuneSport 14.50 rear tire (Funco tire)17 in rim comp cut (save 11lbs per tire)
$63K OBO
Electric steering
2 inch hollows
$63K OBO
