Motorhome Brakes
Cookie
I have a 2005 Workhorse chassis, Fleetwood Pace Arrow on 22.5 rims/tires.  I just got a quote for doing the brakes, Front with new rotors  $1405, rears with pads and machine the rotors $825, total brake job $2230...........................is it me or is this expensive?  I never owned a Moho long enough to have to do the brakes, I do them myself for all my cars and trucks, what am I missing here...........................
Not sure where you are, call Colton Truck Terminal in Colton.
I think I paid $700 for some new front pads, oil put into the hubs and cleaned up the rotors. Same rig. I was happy I didn't have to lift a finger. Haha.
Its not you, that's pretty expensive for that job, is it a mobile service? That could explain some of the cost.
dont know what the parts cost with out some more info but i would expect around 200 a wheel for labor
This is at a RV repair place, think I will call Colton tomorrow.  They just charge me $1500 for fuel pump and housing, had to drop the tank.
That is a little steep. Rotors are so cheap anymore that I never bother with machining especially rotors that big. I just did a brake job on a medium chassis like that. Tree trimmer’s truck but pretty much the same parts. Hydraulic brakes with 22.5s. Rear rotors we’re about $200ea and front rotors were $165ea and the premium pads are about $150 a set. Plus about 5 hours labor. I did a clutch and a number of other repairs but the brake job ran him about $1500 and I did the work at his site.
I called Colton, they said they only work on air brakes anymore...ugh
I did not ever think I would say this. Did you check the dealer? LOL
Is there something wrong with your rotors? Did they get down to the metal on one of the pads? Warped? It’s pretty hard to warp those big rotors. If you don’t have any damaged rotors then just slap some new pads on for $300 and be done with it.
Does your Workhorse chassis have the brake caliper recall?  Mine did as they were sticking.  That overheated the rotors and wore down the pads.  They paid for new calipers but said the pads and rotors were wear items.  $3,000 later and I have all new brakes.
Don't know how big the chassis is but on a Ford F450 or F550, Book time is 4hrs for front and 4 hours labor on the rear and that includes cutting the rotors.
We had to buy a couple calipers for the same tree trimmer’s truck a few years ago because he wore the brakes down past the metal behind the brake linings and was dragging the caliper’s pistons on the rotor. They were surprisingly inexpensive and came loaded with new brake pads. Less than $100 per loaded caliper I think.
They are on metal on metal on the fronts, at least sounds like it, blew me away at 31k miles.  Buddy has the same Moho at 50k with 60% of his brakes left.  I do know, the previous owner towed a stacker trailer with the Moho over I-8 with no trailer brake controller.  He spent the money to beef up the hitch, but no brake controller.  I have talked to a few people today, they are said that price isn't out of the ballpark.
no idea
Looks like I am going to suck it up and get it done.............was looking to buy a new Motorcycle, I guess that is on hold, HA
It depends on how you drive them. I see guys with those bigger chassis make brakes last forever and other guys needing them twice a year. Obviously, towing makes a difference too. I have a few business class trucks for I use for work and personally I won’t even look at one that doesn’t have air brakes unless it’s a steal if I plan on keeping it. Two different tree service companies, two boom trucks that both tow comparable chippers behind them, both have hydraulic brakes and ironically the guy that makes his brakes last has no brakes on the chipper axle and other guy has working brakes on the chipper and needs brakes on the truck and chipper all the time.
