Dockmaster
- 1,046
Just finishing up reinstalling my 2D trans after rebuild in a mid engine application. I have the PBS cable shifter. Are there any tips or tricks to getting the shift linkage reattached properly so it is in the proper gear to match the shift lever?? Which gear is where on the linkage back on the trans? Is first gear with the linkage arm all the way to the rear of the car or? Where should the arm be for 2-3-4 gears? Is there a particular gear/location I should have the shift lever in when attaching to the linkage arm on the trans? Again this a mid-engine setup. I couldn't find a manual online anywhere. Appreciate any help. Thanks!
