Dockmaster
- 1,086
Since my trans is out for rebuild seemed like a logical time to do a full service on my 930 CVs. Unfortunately, I forgot to mark my axles when I removed them as I was focused on the trans removal. I just pulled the CVS off the axles and cleaned everything up and inspected. I did mark the CVs and axles so I can put the CVs back in the same spot. CV components all looked good with no real pitting or obvious issues. The splined portion of the axles is longer on one end of the axle than the other. One end has about 4” of spline whereas the other end is about 3”. Does the end with longer splines go toward the trans? I’m assuming this is correct but wanted to confirm.
The other curious thing I found is on each axle one of fhe CV cages is more highly polished than the other. This is the same on both axles. One of the CV cages is like a chrome finish and the other one is a more dull, basic machined finish. Is this normal? This does not appear to be from wear or anything like that, just clearly a different finish on the cages.
