Jammer75
- 518
It’s a vented cap and only happens when tank is full leaks when hills climbing or side hilling. Once gas level goes down it doesn’t do it. Was wondering if there was anything other than maybe putting and extension hose on it clamped to the fuel spout on the tank and then up higher and mounted to the frame higher with a cap…???Is the cap vented? Some caps have a very tiny hole for venting.
If the cap isn’t vented check your vent line to the tank. If clogged it may be building pressure in the tank.
The safest way is as Alper said and use a non-vented cap.It’s a vented cap and only happens when tank is full leaks when hills climbing or side hilling. Once gas level goes down it doesn’t do it. Was wondering if there was anything other than maybe putting and extension hose on it clamped to the fuel spout on the tank and then up higher and mounted to the frame higher with a cap…???
X2 Perfectly assessed pressure needs to go somewhereIs the cap vented? Some caps have a very tiny hole for venting.
Why is it leaking?I just did this today on my car. I was hitting a flar spot on the gat / throttle . I pulled my tank out and cleaned it. There was a gas hose in there from a 5 gallon gas can and a piece of the fuel tank from when it was drilled for the fuel gauge.
i cleaned the tank and took the filler neck to The man with the mullet. He welded a brake fitting and told me to loop a lineup and run it down.
got it all back together and changed the fuel filter too…….my line is leaking so tomorrow I am gonna pull it apart snd fix the fitting
pain in the AZZ
here is a pic of the vent / the new gas cap had a rubber gasket that sealed much tighter than the cork one / tank needs to breath so hopefully this helps and its safer if you roll and fuel wont leak from the cap
May be the washer on the fitting / new filter came with a coupleWhy is it leaking?
How old were the lines and what fuel do you run? You saved a major leak and fire if the other lines looked like that!Found the problem and replaced both fuel lines/ got it all PAINFULLY back together and buttoned up
no leaks and no more hesitation at all
motor RIPs!!!!!
now gotta clean up the mess / shower and a cold frosty with my buddiesoule:
Probably 19 years / I replaced a bunch of it. Peace of mind / been doing stuff every year. This summer I an gonna do a bunch of stuff I wasn’t able to do this yearHow old were the lines and what fuel do you run? You saved a major leak and fire if the other lines looked like that!
