acefuture
- Jun 8, 2021
- 365
- 604
So I'm going down the road of getting my car correct. It's never quite been right. It's a DD sand car chassis, car weighs about 2600lbs without people in it. Don't know exact corner weights unfortunately. Here's my dilema; my car has 2 interesting features. The original springs on it are completely unknown. They aren't king, eibach, hypercoils, etc. and have no markings on them. They've also been powdercoated about 15 times. I also have coilovers that do not run any nitrogen, they are essentially a coil carrier. I may change that later with a new cap and turn it into an emulsion shock.
So I'm starting from scratch. I had a shock guy rebuild them for me since I kind of botched it the last time I did it. And we ordered some new eibach springs. The fronts are a good starting point, but the rear is wear I'm stumbling. We started with a 275 over 350 to see how the car sat, then would make adjustments. It was so soft the car sat on the ground. So we jumped it up to a 400 over 500. The car is obviously higher, but I need another 4" to reach correct ride height. So we're bumping up to a 500 over 650. When I input numbers into a spring rate calculator it says 400 over 550 or in that range. What are other DD owners running? I know there's some drastic differences in cars, but want to get a pulse. We'll get to valving, secondaries, tuning etc once I get the correct ride height.
Photos of the car for reference with original springs on the rear
Photos of the 400 over 500
