- Thread starter
- #9,421
Sand Shark
- 4,835
Desert is the easiest on belts.Clutching seems "loose" to me (I assume because the 300hp turbo is laggy on a 1.0L engine), and there has to be a lot of heatsoak after you turn the thing off and airflow stops. Curious what the belt temps end up at after sitting for a beer break for a bit.
I assume this didn't come up during testing because it was at a track (consistent input) or RG was driving (WOT at all times). Not everyone can drive in the dirt this way, and throttle transitions are hard on belts.
I just read on another forum that 15/34 cars out in the wild have broken belts (it was a screenshot from FB). If true, that many breaking belts is not a driver issue that is a Speed design/set up issue.
Hope they figure it out before the Speed UTV owners start scattering belts across the dunes and create "speed" bumps (formerly chatter bumps). If a Speed UTV creates chatter bumps are they double sheared and safe? LMAO!!!!!
