Rockwood
- 8,485
We're certainly censored like network TV here these days... :biggrin:GD.Com CSI. You guys should have your own TV show.
Good catch.@Sand Shark I thought that as well, but it could be at the Hisun factory judging by this picture. Look at the upper right hand corner. Looks like a piece of material with a Hisun logo.IDK.
If they're using parallel assembly lines they could be building these at the advertised rates. In the beginning, RG stated they will produce 40 per day. His most recent videos, he's been saying 50 per day. If they're running 3 shifts at the factory, that's only about 2 per hour. If they're running 4 parallel lines, that's only 1 car for every 2 hours per line.They're assembling these at individual component (drivetrain is being assembled part by part) with hand-held tools out of boxes of parts on roller carts with tie down straps square-knotted to them so they can be moved around... These may be production parts from suppliers, but they still have a lot of logistics before they're at Full-Rate Production. Sorry to say, but I don't think 1,000 are gonna be built next year...
Is that zerk fitting for the outer CV joint?That would be cool but I doubt it.
Here’s a few more pics RG had posted but I can’t seem to find them now. Grease fittings on the bearings is a pretty cool feature.
His race shop in NC is full of semi trucks, race trailers, SST truck chassis, stacks of replacement SST bodies, trophy trucks, spare parts, a small assembly area where they assembled the first 2 prototypes, etc. That shop doesn't have any spare room anywhere near that large, plus that's a different style building with a different ceiling.Almost looks like they are assembling them at his place in N.C.
The “method” illustrated above is super low volume and high cost. How would they scale with the labor pool? Assume it scales, what about the $40k MSRP?If they're using parallel assembly lines they could be building these at the advertised rates. In the beginning, RG stated they will produce 40 per day. His most recent videos, he's been saying 50 per day. If they're running 3 shifts at the factory, that's only about 2 per hour. If they're running 4 parallel lines, that's only 1 car for every 2 hours per line.
But let's assume you're correct and they don't figure out the best/fastest method. There's 16 months between now and Dec.31 2022, so they only have to produce 3.125 units per day, 20 days/month for the next 16 months to produce 1,000 units by then.
Even if they only hit 1/8th of their production goal, that's 5 units/day, 100 units/month, 1600 units by the end of 2022. Not that I foresee that slow production rate, but that is 60% more than 1,000 units.
From the videos I've seen on YT, everyone is assembling engines and transmissions by hand, albeit on motorized trolleys between stations. The only real hand assembly on these UTVs would be the engine, trans, front and rear diffs, dash, front and rear suspensions, wiring harness and the roof. The chassis and suspension arms are all CNC cut and bent, then robot welded.The “method” illustrated above is super low volume and high cost. How would they scale with the labor pool? Assume it scales, what about the $40k MSRP?
That vehicle, assembled by hand component by component, even with a crack crew, has hundreds of hours of assembly in it.
I get what you’re saying…From the videos I've seen on YT, everyone is assembling engines and transmissions by hand, albeit on motorized trolleys between stations. The only real hand assembly on these UTVs would be the engine, trans, front and rear diffs, dash, front and rear suspensions, wiring harness and the roof. The chassis and suspension arms are all CNC cut and bent, then robot welded.
As for the cost... well, I paid $30k for mine, plus delivery, tax and doc fees. If someone pays 40k or 45k in the future, I feel sorry for them, but there's nothing I can do about it. Even at $45k, it is probably still a good value compared to what else is out there, including custom built.
I'm hoping they figure out more efficient assembly methods as they learn from these early days. To their benefit, they don't have 20 layers of vastly overpaid executive fat adding huge overhead to their operation. Everyone in their org is productive, rather than most auto corporations who have an executive assistant director to the vice president of sanitation operations who earns $1M/yr because he's married to some VP's sister.
I think it was 3 weeks ago that RG said they were figuring out the mfg process as they go along. I think he's a fairly smart guy, so I'm hoping he figures out a way to streamline the process.I get what you’re saying…
But Robby’s words are this is the assembly process. If so, it’ll be 2027 before orders are filled unless he just throws mad duckets at this shiznit. :biggrin:
That, or he’s full of it and they have a bunch of logistics to figure out…
EEEKK... yeah, I'm not a welder,.. but yeah.. that's someone who is 'learning on the job.
On 8/27/2021 at 7:45 AM, onanysunday said:
