Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,520
- 2,787
What size are the fans?You can help me re-engineer my cooling system on mine! I need to look into the better fans that aren't insane $ and some shroud mods, probably.
-TJ
-TJ
Is there anything sealing the radiator to the surrounding shroud? Anything to direct air upwards so it enters the radiator at a 90* angle?
Do I have to? :biggrin:You can help me re-engineer my cooling system on mine! I need to look into the better fans that aren't insane $ and some shroud mods, probably.
Honestly, even in front when I had Clay's Z1 car it was an issue. The front tires on these super-wide SxSs sit far enough forward, and out wide enough that they throw stuff (even dust) onto your own windshield.
-TJ
I think someone posted on the Speed forum, perhaps along w/ the SPAL part numbers to replace/upgrade them.What size are the fans?
Yes?Do I have to? :biggrin:
Have any pictures of the inside of the shroud from the front? It looks like it clamshells over the cooling package, but the offset beauty cover on the back side, combined with what appears to be no sealing on the front makes me wonder if air is hitting the shroud on exit and just looping around to the front.I think someone posted on the Speed forum, perhaps along w/ the SPAL part numbers to replace/upgrade them.
Yes?
-TJ
I'll try to get better pics this weekend, hopefully taking it out for some miles on Sat.Have any pictures of the inside of the shroud from the front? It looks like it clamshells over the cooling package, but the offset beauty cover on the back side, combined with what appears to be no sealing on the front makes me wonder if air is hitting the shroud on exit and just looping around to the front.
That sounds like what some have been saying. One of the reasons is due to the extreme heat coming in to the cab, backseats, from the radiator. Fans should be pulling air out and it seems like they can’t overcome the high pressure. Some have tried a rear window others are playing with higher cfm fans. I believe @RiverDave is experimenting with a scoop that sticks out further than the windshield? Saw a picture of that somewhere.7 hours ago, Rockwood said:
Not sure if that will help unless it's a Gonzo nose. The steeper windshield will cause flow separation much sooner than the RX7 pictured above.That sounds like what some have been saying. One of the reasons is due to the extreme heat coming in to the cab, backseats, from the radiator. Fans should be pulling air out and it seems like they can’t overcome the high pressure. Some have tried a rear window others are playing with higher cfm fans. I believe @RiverDave is experimenting with a scoop that sticks out further than the windshield? Saw a picture of that somewhere.
No light bar in those pics. It is more effective at forcing air into the passenger area.Look up @theJakevelasco on the Instagram, he has a new roof scoop, with ducting back to the radiator, he's claiming it works with the windshield and no other mods. Tested in 100 degree weather.
Jake says his roof does not work with the light bar.No light bar in those pics. It is more effective at forcing air into the passenger area.
I follow kingadam on instagram who used to post on this website few years back and seen this on his stories. He puts out some nice work out of his shop and thought this was interesting. Might solve some of the issues with the negative pressure.
Your trip to Mexico will be the ultimate test.So my car is down at Morgan motorsports right now getting their oil cooler / roof scoop / eibach springs
With the oil cooler and the roof scoop the car will run normal temps even on hot days running the shit out of it..
It also adds four quarts of oil which helps considerably.
View attachment 124382View attachment 124383View attachment 124384View attachment 124385
