Rockwood
- 8,516
The triple rate setup? Carl's using it for exactly what you're complaining about: more bump zone control. Using a firmer rate in the final bump zone makes it so you can run a softer shock (compression, at least, rebound will need firmer valving to prevent bucking off of the bump zone) since the spring is taking up some of the work. A cheaper way to accomplish this are running a larger poly stop to at least cushion the last little bit so it squishes off the stop rather than clangs off of it.A Little update as i forgot about this post.
the last two trips taken with the new shock tune and coil setup was absolutely 100x better than before chop is almost gone but i had to sacrifice some bump zone control. So ill continue to experiment as I go.
I did have one question though.
check this setup out. I have seen this on a few cars now and know this is one of Carl's secret sauces.
can some one explain how this works? I have a few theories but I would like to discuss with my dune friends.View attachment 145740View attachment 145741
