wesinls
- May 6, 2021
- 970
- 1,228
No, I actually measured a little over .200” clearance from the t/o bearing to the clutch fingers.Correct. But is the t/o bearing making a small amount of contact when disengaged? The thought I had was will the noise go away or change with just a slight amount of pressure on pedal.
The pilot bearing rotates very smooth with no tight spots, it really feels good. I would think I could feel a bad bearing…… yes / no?The pilot bearing also stops spinning (somewhat) - when the clutch is engaged correct? Possibly it was damaged during first removal / first install?
I have one - but I also have this shaft I just had to replace from my S5 - it can be used an input shaft....are you in San Diego? I don't want to ship it (too lazy).The pilot bearing rotates very smooth with no tight spots, it really feels good. I would think I could feel a bad bearing…… yes / no?
The rubbing sound makes more of an intermittent type noise like something is out of round, not the typical bad bearing noise. However, I suppose it could be resonating through the transmission. I’m going to pull the trans again next week (4th time) I will replace the pilot bearing just to totally rule it out, but I’m confident that’s not it.
This is a mid-engine, so I have done all of this moving the trans back about 8”, not a fun way to replace a clutch, I will probably have to totally remove the trans to replace pilot bearing.
Does anyone make a GOOD clutch aligtnment tool? these cheesy plastic ones are horrible !
I’m in San Diego today & tomorrow, (Point Loma) I live in Corona, I can deliver it or ship it back from my business.I have one - but I also have this shaft I just had to replace from my S5 - it can be used an input shaft....are you in San Diego? I don't want to ship it (too lazy).
Clutch pedal in, pilot spins. Clutch pedal out, pilot doesn’t spin. Seems it would be the opposite if the pilot was hosed. Same with thrust bearing problems.The pilot bearing also stops spinning (somewhat) - when the clutch is engaged correct? Possibly it was damaged during first removal / first install?
