jareddustin
- May 6, 2021
- 313
- 231
i have a 21 turbo S so not quite the same measurements. it is wider with the sand tires, on my flat bed that is around 77' wide between the fenders i can get the car on with the dirt tires but with the sand tires i had to jack up the front and strap the suspension to clear, the rear the tires would hang off a little. i have a 2009 weekend warrior 5th wheel. the car fits in with sand tires not having to do anything special its a tight fit between the wheel wells inside the trailer, i dont have drive over. the rear is no issue. height i just get under the rear bunks. the pro R is taller than the turbo S. there have been threads on the WW page about getting a pro R to fit, seams that the height is more the issue with the pro r getting under the rear beds.From my experience Skats run tall. Here’s is what I’m after. My stock Pro R will fit under the rear bead driving the car in with two people in the car. If it’s just me, the radius part of the cage hits the bed. If I back the car in it clears by an inch due to the dovetail on the trailer. Now when I buy my sand tires the car will definitely get taller as I plan on running Tensor 33’s. Just not sure how tall they actually are. This will tell me if I have to let air out to fit or ratchet the suspension down. The other issue I will run into is how much wider the car will be with the sand tires. I’ve gotta figure that out to know if it will even fit backing it in or if it forces me to drive it in. At first I never thought it would fit at all but I gave it a shot last weekend and was surprised. Just want to have all my ducks in a row when season hits!
