Sandkist
- May 6, 2021
- 2,866
- 651
Looks like sandblasted chrome.I want to see pics of that. Sounds cool.
Pencil me in!I can't wait to see some wiring get thrown at this project! It needs the full lighting package, including pink vag lights (under the seats, facing forward, lol) !!
I'm on it. This is definitely one of my "don't f*ck around and try and grow a brain" areas with this car. We're measuring everything and writing it all down. I'll also be measuring and checking alignment and cycle on the suspension before taking it out.I saw your Facebook post before this. Heed my warning about the heim joints, alignment, and axles.
That girl has been on that car for long time!
Yes she has. It was a stipulation in buying the car...the girl had to come with... :lol:That girl has been on that car for long time!
I’m surprised Brian let her go!Yes she has. It was a stipulation in buying the car...the girl had to come with... :lol:
It was a hard choice for him but his wife said they needed 4 seats. I will say I have loved this car from the first time I put my foot on the throttle.I’m surprised Brian let her go!
He’s in Parker usually not far from you.It was a hard choice for him but his wife said they needed 4 seats. I will say I have loved this car from the first time I put my foot on the throttle.
No. The geometry and setup of the car is perfect.View attachment 97217
Ever thought about changing the shock mount braces to more of an x brace. Shock mount to corner of the frame x 2.
Keeping the pimp hand strong!You make Stef park outside? :ban:
What was the warning? for those of us that don’t do the F book.I saw your Facebook post before this. Heed my warning about the heim joints, alignment, and axles.
Basically, you got to get the new heim's threaded in as close to the old ones as possible. If you don't, you can move the spindles closer (or further) to the transmission causing the axle to bottom out, which will cause either the spindle to break or you rip tabs off the frame. (Ask me how I know lol ) or if it's too far, the axle will pull out. Your alignment will get whacked as well and your rear end will be all over the place at speed.What was the warning? for those of us that don’t do the F book.![]()
I ain't scared... did used to rig jet engines and turboprops back in the day... :lol:Basically, you got to get the new heim's threaded in as close to the old ones as possible. If you don't, you can move the spindles closer (or further) to the transmission causing the axle to bottom out, which will cause either the spindle to break or you rip tabs off the frame. (Ask me how I know lol ) or if it's too far, the axle will pull out. Your alignment will get whacked as well and your rear end will be all over the place at speed.
Lastly, you need to double-check axle length when you're all done to make sure. It can be a real mother to adjust those five links.
I think he's going to find that each side isn't the same.
If I were to do it all over again, I would swap out all my heims, get the rear as even as possible, and then aligned... then measure for new axles last. When you're using the old axles you kind of have to work around those measurements. Some of my heims were almost threaded all the way out on one side to get the alignment correct.
If his car was set up properly from the get-go he probably won't encounter the problems that I had.
