lincster
- 641
Kennedy has a good explanation on different stage clutches.Picked up a set of Headers and got the Engine back from machine shop. Ready for the kitchen rebuild!
What fly wheel / clutch setup do I want? Will be paired up to my 2D transmission.
What is the difference in stage 1-2-3 clutch? Plus minus of one over another?
My old ecotec had a stage 3 clutch and was very hard to push the pedal
When I ran a stock LS1 and a 2D, I used a 8" dual disc with Stage 3.
Pedal pressure can also be changed by changing the master cylinder size.
I have an entire clutch assembly if you are interested, but it is 9", dual disc, stage 4.
Will still work for your setup, just more than what you need.
