J Alper
Site Sponsor
- Apr 30, 2021
- 1,990
- 1,727
I was looking at Redline's site, how do I determine if I have a Y body or an F body engine? Their site doesn't give any extra details.
https://www.redlineperformanceinc.com/collections/cooling-system
That is correct on the Belt line but what Redline is talking about is, is it a LS1 style pump with the big bell, or the skinny pulley (ls3)the difference is the belt line. https://www.ictbillet.com/swap-guide/ls-swap-guide.html#cat-556
So the LS3 pump has a different bolt spacing on the water neck, just slightly, and the diameter is different on the thermostat size,
Like i said before if you post a picture of the motor, it will help,
Most likely you will need the F-body pump - most Y body pumps are used with the Whipple SuperCharger,
