Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,507
- 2,777
The J series (and most Hondas) trigger the fans on the cool side of the radiator. The lower temp switch is made by Mishimoto.One thing with the Fans, mine struggle to stay cool due the fans not coming on until 205, that being said they would also turn off at 205, and always had the temp cycling between 200 and 215, occasionally 220. I finally put my fans on a switch. 215 is way too hot.
Then I think Kruat said you can change out the sensor to an 180 degree sensor, I have never had an issue since. No idea why that sensor was originally 205 degrees.
I believe the AEM has the provision to trigger the fans through an output referencing the actual coolant temp sensor. You would most likely have to add the wire back into the ECU connector.
Have you looked at your radiator fins or fans recently? Before the crash Kurtis @onanysunday did a write up about his cooling system being pretty hammered. Most the the radiator fins were laid over from being sand blasted. The fans were in pretty rough shape too.
